Ford 641 Lift is slow up
   / Ford 641 Lift is slow up #1
simpleman7140
Rogers, AR
Ford 641
My tractors lift would leak down in about 5 min when shut off and when running would drop about 2" and bounce back up. the pump seems to be in good working order. I have recently rebuilt the cylinder in my 1959 641. the piston oring and backup ring were in poor shape. It worked great and would hold rock rake up for a week while sitting. I put about 2 hours on it after rebuild and then it started lifting slow and will leak down overnight now.
It had Mystic JT-5 in it before the rebuild. I used different hydraulic/transmission fluid when I rebuilt it and changed the fluid.
I looked in the side cover today and i have a stream of fluid running out of the front side of the unloading valve about the size of 2 pencil leads when the lift is all the way up and small drips when it is moving up. Nothing out of the piston. It runs down and into the the reservoir. It is creating fine air bubbles when it hits there. Is this normal? Could this be enough air to get in the pump.
I am also getting air in the pump which is a piston pump. I can bleed the air out from the plug on top front of the pump. This changes nothing the lift stills rises slow. There were no pump issues before the cylinder was rebuilt. Has anyone had this issue?
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
