CJC12
Hello,
First off I'm glad I stumbled across this great website. It is full of valuable information and from what I've read the forums are excellent!
We recently purchased a property that in my opinion needs a tractor.
It is only about 3 acres but I would like something with an FEL as well as a backhoe (or at least one that would accept a backhoe implement) for digging and taking out some (well, quite a few actually) little stumps. Additionally, I would eventually like to get a bush hog for weed abatement on some investment properties I have (.5-10ac).
The property just purchased has a water runoff ditch through the side of it that will need from my calculations somewhere around 3000 cubic yards of fill. This will be an ongoing project...
You're probably thinking with 3000yds of fill that needs to be moved around I'm going to need something big. I know it's not going to get this done overnight but I'm just going to make it a long-term project.
From what I've read a compact with say 35-40hp should be ok. What do you think?
I'm not ready to plop down 15-20 grand for a new tractor so I'd like to buy something used. Granted, I don't see many used compacts out there. Maybe this is a good sign!
In the meantime while I'm trying to find the tractor that would fit my needs, I'd like to get something cheap just to get me started in this whole tractor scene.
I found an old Ford 601 in the local classifieds. The owner says there is a bucket in the front and a box scraper in the rear.
From the pictures of the Ford series from that era I can't quite see how an FEL would be attached and operated. I'd love to show you a picture but the owner doesn't have one and before I drive 3hrs to look at it I'd like to know a little more about it. Does anybody know if this was an actual implement or if it must have been some kind of add-on?
I've read that the older Ford farm tractors have a pretty good reputation as far as reliability. Is this true with the 601 series? What should I expect as far as power output? How much does it weigh? Are parts tough to find?
Any information about this tractor would be useful. Like I said earlier, this is will be sort of a "starter" tractor, but I'd still like it to be pretty useful and proficient (at least for moving dirt).
By the way, the owner is asking $4500 for it and says it's had "average" use. Does this sound high or low?
Thanks in advance for everything guys!
Best Regards,
Carter
Best Regards,
Carter
