Ford 6000 Steering Issues
   / Ford 6000 Steering Issues #1
MH49
Ohio
CASE IH 5220; Cockshutt 570 (2x); Massey Harris 44; Ford NAA; 1872 Super Cub; MF 14, 12 and 10 Garden Tractors
We are working on Ford 6000 that the power steering is not working. Pressure test shows it only has 800 psi when the steering dead-headed one direction. We have the pump off and it looks to me that the relief valve is stuck closed but the bypass piston is free in the bore. The oil had a lot water in it which I am affraid may have caused havoc in the whole system. We have not taken the pump apart yet to inspect it but I am hoping someone has some experience with these systems. It is my understanding that the pump is the same as the 800 series????
   / Ford 6000 Steering Issues #2
Here's what I see on the website:
C7NN3A674K PUMP, HYDRAULIC Pump Assy., Power Steering, 1100 P.S.I.-287 U.S. Gal. at 1,000 R.P.M., L/External Gear, Includes: Ref. 1 thru 36, No Longer Serviced, Start Year: 04/01/1967
   / Ford 6000 Steering Issues #3
G'day if you have a look at the BareCo site you will find that a replacement pump is not that pricey and it ups the relief press to 1500 psi which is great if you have got a FEL but i think you will find that when you stir the pums it will be u/s good luck though:)
Here is an update. New Holland does not offer a rebuild kit for the roller type pump however, the owner was able to find one at a dealer. It wasn't cheap but it fixed the problem and steers like a dream now. Thanks for the help.
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
2020 John Deere 6110M 110HP 4WD Agricultural Tractor (A49461)
2020 John Deere...
(2) 15X8 RIG MATS (A50854)
(2) 15X8 RIG MATS...
