Ford 600 high crop 1955
   / Ford 600 high crop 1955 #1
andrewj
Platinum Member
South Carolina
JD 5105
is a shed kept running model worth around 3500? I thought the "high crop might make it worth more. Thanks.
   / Ford 600 high crop 1955 #2
A good running / condition hundred series can fetch in the 3??? range. Special options help support that price.
600 is the series.. post the actual model ID number. This will tell you about trans and hyds.. etc..
5 spd is worth more than the 4 spd... and the live pto 5 spd is worth the most.
Options like factory power steering are a big plus if they still work..
Soundguy
   / Ford 600 high crop 1955 #3
Is it a true Hi-crop, or a 700 or an offset 500. I can't say as I've ever seen a hi-crop 600, it may be a rare bird and coulf fetch a pretty penny,later, Nat
   / Ford 600 high crop 1955 #4
That's why I'm trying to get him to post the number ont he tranny casting.. to see what he actually has... never know..
Soundguy
Soundguy
well i don't know, it was an ad, I will try to get that info from the seller.
Soundguy
Here's the advertisement as listed:
'55 FORD TRACTOR, VGC, 800 series, 5 spd. trans, w/live PTO, high clearance row crop type equip. w 172 cu. in. eng. shed stored, antique $3500
What say you gurus?
EDIT - as to the other questions, I have tried to call the guy and no answer, I willt ry back after business hours.
   / Ford 600 high crop 1955 #7
All I can say is he must like to type... most of the stuff he said in his add was redundant.
800 series, 5 spd, live pto, 172cu eng
all that can be said as: 860
8 means 172 gasser 6 means 5spd live pto.. 0 means 55-57 year range
As for hi clearance.. well.. lets see a pic... I supose it could have had custom work done on it. i have seen a special hi crop- 8n with spindle extensions and gear reductions all done aftermarket.. etc.. so.. anything is possible.
soundguy
What say you gurus?
   / Ford 600 high crop 1955 #8
Chris, it sounds like a 961 to me that may have 861 decals. Thus the " Hi-clearance row crop. What do you think? later, Nat
soundguy
It was from a farmer's bulletin - most folks in there are just salt-of-the-earth simple folk. No pretentious people there that I have met as of yet. And I imagine the details help most folks, since unlike me, most folks don't have access to THE Soundguy! I will keep calling as I want to ask about the highh crop aspect.
came from factory as a high crop, wide front end, also got live PTO, no power steering, original paint, his daddy bought it but then got a job with a local factory and ended up not using it that muich.
he said it was red with beige colors? I thought they were blue and white, but it is a 1955 so maybe they had them red at that time. starts and runs good. Your thoughts? he is firm on 3500
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
