Ford 6' flail mower too much for a BX24???
   / Ford 6' flail mower too much for a BX24??? #1
Carnut68
Southbury, CT
Kubota BX24
I am in possession of a 6' Ford flail mower that's in good shape. I need a mower to mow several acres of field/pasture once every 3-4 weeks, slightly sloped but not bad. I think flail mower is the way to go but should I try to use this with my little BX24 or try to sell it and get a smaller one? The flail weighs over 600lbs not sure if that just too much weight. Most newer flail mowers of that size seem to recommend much more HP tractors than my 18HP (PTO) but the prior owner said he used it with a JD 750 or similar small tractor. I am taking that with a grain of salt and would rather get some unbiased opinions here. Would love to use it but don't want to risk my machine.
   / Ford 6' flail mower too much for a BX24??? #2
I wouldn't be comfortable with that combination.
It's way over the Kubota recommended limits.
For example, my BX 2660 (25.5 & 19.5 HP) is rated for a 42" flail mower, and max weight of 300 pounds. I realize these are conservative and folks go over then often, but, in your case ...
   / Ford 6' flail mower too much for a BX24??? #3
Give it a try. I think it will be fine, you might need to slow down a bit. Kubota is always conservative with their attachment recommendations.
   / Ford 6' flail mower too much for a BX24??? #4
You have both tractor & flail mower. Why not hook them together and see for yourself?
   / Ford 6' flail mower too much for a BX24??? #5
My thoughts exactly! You will know...and then let us know!!:thumbsup:
I should have mentioned that the mower is not presently in the location where I can try it out. I have to haul it three hours north to my other property. I didn't want to bother if I didn't think it had a decent chance of working. But it looks like I might as well give it a shot.
   / Ford 6' flail mower too much for a BX24??? #7
Exactly what I was gonna say:thumbsup:
Now this makes sense. However, I'd still be curious on how well it actually performs with that combo.
   / Ford 6' flail mower too much for a BX24??? #8
I have a Ford 90" flail that I use behind my 955 and am happy with it. That works out to 3.3"/HP. It mows 18" grass with no problem, just need to slow down a bit. Your set up will be 4"/HP so you'll be borderline, but you can always slow down.
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
Hyster H225E (A47384)
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
