ford 5600 pto shaft bearing
   / ford 5600 pto shaft bearing #1
tazzer
omaha tx
ford 2120
I had to replace a broke pto shaft on my 5600, I got the old shaft out but cannot fig. out how to remove the bearing from the old shaft to put on the new.
thanks for any help
taz
   / ford 5600 pto shaft bearing #2
If you could post a pic it will bring in some good advice. Also google in Bearing Puller images to see if one of the many styles of these makes sense. Does the bearing stick out beyond the diameter of the shaft? Might be able to remove it with a press.
heres a pic, I went ahead and ordered a new bearing and think Ill just carry it somewhere to have it pressed on lol.
   / ford 5600 pto shaft bearing #4
Yes, easy work on a press!
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
MISC WRENCHES AND SOCKETS (A53843)
MISC WRENCHES AND...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
