AlanB
Elite Member
My Ford 555C has started making oil, while normally things that produce oil would make me very happy, somehow I suspect it is just moving an oily substance around within the motor which makes me a little unhappy.
The last thing I did on the hoe was to change the o-ring seals in the top of the fuel control, they were shot and leaking. Following my normal course of troubleshooting, I always suspect the last thing that was touched as the most likely culprit.
I suspect that the seal in the front of the fuel control is leaking as well, or maybe more as probably sealing the top up, forced it to go to the next weaker seal.
Utilizing my well calibrated nasal gas chromatograph I am pretty sure what I drained was diesel added to my oil, but am not positive. The oil viscosity also appeared substantially thinner and I did not see any emulsion.
Also as I drained it, it had the "bubbles" that I associate with Diesel.
I will probably speak with the oil lab that I work with and see if they can look at it and give me some insight.
I am also "loosing" power steering fluid (TDH oil) which I imagine could also be going in there, and would also reduce viscosity, but the oil around the pump and piston area makes me think it is just leaking around the normal area's.
So, my questions would be
1. Is there a way to positively prove / disprove the front seal on the fuel control?
2. Anyone seen something similar, something to look for that I am missing?
3. Should I just use the fuel control shop that the local guys use, or should I send it out to someone? (anyone on the board do these controls?)
4. Related question, anyone used one of those CD copy manuals they are selling on e-bay? $25 sure sounds a lot better then $150, at that price I think it is worth the risk, but would feel better if someone had used one already.
Thanks for your thoughts and input.
