Chewwy
Platinum Member
- Joined
- May 5, 2015
- Messages
- 792
- Location
- Upstate SC, Near the Electric City
- Tractor
- Kubota L3240, MF 265, MF383
I need to replace the wet brakes on my 555b backhoe. I"ve been planning to do this when the weather turned cooler. I continued to use the backhoe over the summer without brakes to complete several jobs on some flat pieces of my property. During this use, I noticed a pretty good transmission fluid leak from the fromt of the transmission (4x4 power reversing transmission). Likely it's a transmission oil seal or gasket.
To replace the brakes, the service manual calls for removing the backhoe, then split the unit and remove the rear axle to access the axle "trumpets." Replacing the transmission front oil seal require removing the transmission. To remove the transmission, the service manual calls to first remove the engine, then remove the transmission. Since axle removal to replace the brakes leaves the transmission just sitting there attached to the engine, I'm going to attempt the transmission removal from the rear.
Does anyone have any thoughts on whether this will work or not. Seems simpler than removing the engine to acess the transmission front oil seal.
