Ford 555A control valve
   / Ford 555A control valve #1
maddogoffroad
Dartmouth Nova Scotia
Ford 555A
Any one knows where I can find a use set of control valve for the backhoe. Here the info that I have; 20j03 control valve 4 lever. The wrong pressure was set on one of the "Knife section" and the back of it blow up. I would preferably like to have the full control valve, but I can fix it with one section. I have here at work a shop that can test and set up the relief valve to the original pressure. Any help would really appreciate.
Chris
Can i change that control valve set up, with two 4way joystick? or one of these items at Princess Auto.
Manual Dcv | Princess Auto
BM70 4-Spool Directional Control Valve
BM40 2-Spool Joystick Directional Control Valve
I was down to the hydraulic shop yesterday talking to the guy here at Strickly Hydraulic. He said that it would work, but i wouldn't have any individual safet relief on each one of the section and if something would pall and push the any of the system up it could be dangerous. So i'm still looking for a use one. Thanks J_J
   / Ford 555A control valve #6
If necessary, you can add individual relief valves to each set of work port on the BH valve.
70009 (A51691)
70009 (A51691)
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2019 Ford Fusion Sedan (A51694)
2019 Ford Fusion...
