Ford 550 grease points
/ Ford 550 grease points #1
Mylesb
Bothelll
Ford 550
Hello, I am looking for some replacement grease points for my 550 FEL/BH and I am having a hard time finding them online. The plugs are no longer getting the grease into the joint and are completely plugged up. A buddy with lots of tractor experience recommended just buying new ones but again, can't find them. Anybody have any ideas?
/ Ford 550 grease points #2
If you are meaning the grease zerks, they are 1/8" pipe thread. 27 threads per inch. Some are straight, and some are 90º. Unless the zerks are terribly beaten, or battered, it's probably dirt packed in the hole below the zerk. Remove the zerk, then clean the hole with something like a small flat blade screw driver. In the field, I filled the hole with penetrating oil, replace the zerk, then pump grease in. Most grease guns produce close to 12,000 psi, and will push the dirt out with the penetrating oil, and the grease will follow. You may need to hold pressure on the grease gun handle for a bit, but it will go, unless the bushing has spun over the grease hole.
I don't know if you've found it yet, but there is a grease zerk on the front hydraulic pump drive shaft u-joint. Those wiley Ford engineer's put it in a real tight spot to get to. Our mechanic ended up cutting holes approx. 6" X 8" in the lower front cowling to make it a lot easier to get to.
2007  VOLVO G720B GRADER (A65643)
2007 VOLVO G720B...
2005 Volvo VHD Roll Off Truck, VIN # 4V5KC9GF75N395481 (A65563)
2005 Volvo VHD...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
2019 Mercedes Sprinter 2500 Cargo Van (A64556)
2019 Mercedes...
