Ford 550 converter leak
   / Ford 550 converter leak #1
kafelsan
Finland
David Brown
Hi,
I am thinking of buying a backhoe instead of my David Brown 880.
Have been and checking the Ford 550 -82 4wd. Looks to be a perfect machine for me, just the right size, however it is leaking oil from the torque converter, according to the seller started the leak after he had pushed it too hard. Leaks very fast, can稚 test it.
Have heard / read about and what I can see, there is a lot of work to dismantle the Ford, is there anything special I should consider? I have also heard that it requires precision when to "compress" "front of the cab," and that it will screw the turbine later to avoid damaging it?
What can be wrong if it is not the converter seal?
What痴 the worst case scenario?
Do somebody know the page with pictures where I can see how to take apart the Ford?
Thank you in advance
Fredrik
2022 CATERPILLAR 279D3 SKID STEER (A51246)
2022 CATERPILLAR...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A53472)
John Deere 700...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
