Ford 545C skip loader transmission problems
   / Ford 545C skip loader transmission problems #1
Hankins
I have a Ford 545C with transmission problems. I have the 8x8 power reversing transmission. the transmission keeps slipping in and out of gear, after about 5 to 10 minutes of operation. forward or reverse, doesn't matter. same problem and gets worse the longer its running.
the tractor will work ok for about an hour with minimal sliping out of gear, if it rests for about 2 to 3 hours I can only get about 30 minutes of use until I have to park it. sometimes it will work better in forward for a while then it starts acting up then reverse works good for a while. when it starts acting up the only way to get it to move is to slow engine speed to low idle then transmission picks up and away we go, (for a minute)
I hope that the is somthing simple and not requiring major work.
thanks
2006 Silver Star 8'x102" 5 Horse Trailer (A50123)
2006 Silver Star...
2008 Felling Step Deck Low Boy, 42', 82,500 GVWR (A52384)
2008 Felling Step...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2017 Vicon 764 (A50123)
2017 Vicon 764...
NEW Woods 6ft Finish Mower (A53473)
NEW Woods 6ft...
Miscellaneous Pallet of Road Safety Signage (A52384)
Miscellaneous...
