The
L35 weighs 5997 lbs. with a backhoe.
The
L48 weighs 7760 lbs. with a backhoe.
Comparably equipped with a Ford backhoe option, the 545C would weigh about 11,500 to 12,500 lbs., depending on the backhoe chosen.
In short, the 545C is a Belgian workhorse, the Kubota
L35 &
L48 are both Morgans. Not every farmer wanted to follow a big, slow workhorse around the field one hundred years ago. Many preferred the versatile Morgan. But the Belgian could do what no Morgan could...heavy work.
One thing to keep in mind, the
L35 has the GST transmission and the
L48 is a hydro. These transmissions will make them more nimble to use in addition to their smaller size.
I am personally a fan of the Ford for the reasons that I mentioned in a prior post. They are machines that will run for hours. I still see 40-year old Ford tractor loaders working all the time. There is a local garden center that was using one, day in and day out. Rumor has it that they were closing in on 20,000 hours. Also, don't forget that the Ford 545C has depreciated somewhat and it will lose less of its value over time.
Most importantly, the tractor that you buy is the tractor that YOU will have to be happy with operating...bottom line.
