Ford 5200 slow hydraulics
   / Ford 5200 slow hydraulics #1
hubert32
east central IN
Ford 5200, Ford 7200, Ford 8700, Ford 641
Have a Ford 5200 that came from the factory without auxiliary hydraulics. Previses owner added a Cross single DA remote. Changed remote 2 years ago. The 3 point lift works fine without any trouble what so ever. The problem is the auxiliary keeps getting slower and slower and to the point it won't lift some equipment. Any ideals?
   / Ford 5200 slow hydraulics #2
Can it be assumed that this problem is on more than one piece of equipment? Does the Cross valve have a relief on it? What sort of things are you lifting with the 3pt? How heavy?
I'm not sure if it has a relief valve or not.As far as the 3 point, I'm not sure the weight of a 6 row Buffalo cultivator, but lifts it no problem. Makes the front end lite.
   / Ford 5200 slow hydraulics #4
One more question. It sounds like you may have enough hydraulic pressure. Are you using different implements on the remote that you see this problem or just one implement?
Haybine, planter, disc , but did lift plow ok.
   / Ford 5200 slow hydraulics #6
Is the plow a 2 point with lift assist or 3 point mounted?
The haybine used for lift and or offset?
What size disc?
Easiest way to check what might be culprit, plug a 5000 psi gauge in remote outlet. See if it is in 2500 psi range +/- 200 psi.
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2004 TerraGator 8104 (A53473)
2004 TerraGator...
