Ford 5030 leaking hydraulic Fluid
   / Ford 5030 leaking hydraulic Fluid #1
thestroker05
I have a Ford 5030 and it is leaking hydrauilc fluid like crazy out of the vent. This tractor has a vent up by the gearshifts that vents out of the transmission. When I am using it the fluid pours out of the vent, but when it is running and not moving it want come out. I here no unusal noises or anything from the tractor. I am wondering if the vent has failed me and I need a new one. Can anyone please help me and let me know if they have had this problem or know how to fix it. Thanks in advance for your help!!
   / Ford 5030 leaking hydraulic Fluid #3
There is probably a restriction on the return side of the pump. Make sure the filter and screen (if it has one) is clean.
   / Ford 5030 leaking hydraulic Fluid #4
when its in gear the gear is throwing the oil up at the breather. New Holland replaced the vent plug with a solid plug and drilled a hole further back on the shift top over the rib in the transmission so that the gears could not throw the oil.See your local CNH dealer about the service bulletin from sometimes in the late 90's. Been there done that!!!!!
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2014 FREIGHTLINER CASCADIA DAY CAB (A52577)
2014 FREIGHTLINER...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
JOHN DEERE 648R LOT NUMBER 108 (A53084)
JOHN DEERE 648R...
KMC 5610 (A53084)
KMC 5610 (A53084)
