ford 5000 ring gear
   / ford 5000 ring gear #1
aster
Ford 5000
Can anyone explain how the ring gear goes on a ford 5000 tractor? I am trying to put mine baack in but can't seem to figure out how it goes. Any help is welcome.
   / ford 5000 ring gear #2
generally the bevel on the teeth face the starter drive.
If it is a shrink on gear,heat it up with the torch evenly to about 300 degree and tap it home.
   / ford 5000 ring gear #3
Put the flywheel in your freezer and the ring gear in your oven at around 400F. House may smell funny but this is a shrink fit and trying to heat with torch is a good way to warp the ring gear.
Roy
   / ford 5000 ring gear #4
Flywheel in the freezer and evenly heating with the torch warps the ring gear :confused:
Some people should keep their "expert advice" to themselves ;)
   / ford 5000 ring gear #5
I would also put the fly wheel in the freezer over night helps to reduce the size
But i wouldn't have a problem about heating the the ring gear with a torch just go gentle with the heat and all will be well :thumbsup:
If you heat it in one place with a torch then you will spoil it just go steady and evenly
You will find it will prob fall on if not then a length of timber that will go across the ring gear and a hammer will sort it just be quick about it as the size difference will be short lived
As said above bevel to starter:thumbsup:
Ps my wife isn't very understanding about machinery in the kitchen since she came home an found me baking a cast iron pump housing ready to weld as they are so thin that they crack otherwise
2014 International WorkStar 7400 Truck INOP, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
