Ford 5000 Lift stops working
   / Ford 5000 Lift stops working #1
Werner Peters
Pretoria, South Africa
Ford 5000, MF 135, John Deere 2140
Hi.
My Ford 5000's lifts stopped working while ploughing, and we Removed the Ram-plate to investigate. We found the Pin that connects the Top link to the Draft Control assembly had fallen out. We fished out the Pin and re-assembled the Tractor. When Just Started the Lift Works 100%, but as soon as I drive down to the Fields, when I drop the arms, it will not lift again. With trial and error, I figured out that, if I stop the engine and Leave the tractor for a few minutes and re-start the engine, the lift works again, but only once.
There is enough oil in the system, and I checked the o-rings.
Any help will be appreciated!
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2017 FORD TRANSIT T150 CARGO VAN (A52577)
2017 FORD TRANSIT...
INOP/NON-RUNNING 2012 International DuraStar 4300 Truck, VIN # 1HTMMAAN4CH563891 (A51572)
INOP/NON-RUNNING...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
