jhp123
- Joined
- Dec 16, 2013
- Messages
- 28
- Location
- VA
- Tractor
- 1965 ford 5000 2000 new holland 1920 4wd, 1974 ford 5000, 1975 ford 9600, 1988 case Ih 885
1965 Ford 5000 3 point will not lift or will lift a little but not with any weight on it. We put a new pump and changed all the little o-rings as well as the lift cylinder o ring and wiper on it. It worked for a little while, maybe a couple of weeks, then went un-responsive again. Any other obvious parts i should replace? The aux lines do not pressure up either. They act like they want to but never bog the engine down like it does when it works correctly. The Pto engages fine.
Thanks for any ideas.
