Ford 5000 Hydraulic Top Cover Removal
   / Ford 5000 Hydraulic Top Cover Removal #1
Kevinford5000
Madera, CA
Ford 5000
Hey guys anyone ever taken a Ford 5000 hydraulic top cover off. I'm looking to replace or repair lift cylinder seals and or piston and the filters. I have weak hydraulic power with bobbing/lazy operation of 3 pts lift arms. I have all 14 bolts out of the cover, lift arms disconnected, and Hydraulic remote cover and hoses off. Cover is stuck on there and I don't want to break anything. What am I missing? I have an IT manual but the pictures are poor.
--Kevin
   / Ford 5000 Hydraulic Top Cover Removal #2
From memory of doing this is '84 there is one bolt carefully hidden on the right side while sitting on the seat. I believe it was hidden between a couple of reinforcing webs. Can't remember if there was a line from the hydraulic pump that had to removed through the access hole in the lower right side of the tranny housing.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED TRAILER (A53843)
2010 UTILITY...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
SHOP CART (A53843)
SHOP CART (A53843)
HYDRAULIC AUGER FOR MINI EXCAVATOR (A53843)
HYDRAULIC AUGER...
FUSION PART (A53843)
