ford 5000 gas engine vapor lock
   / ford 5000 gas engine vapor lock #1
albo
luther,michigan
I can run my tractor in the feild for about two hrs when it starts to act like it is running out of gas and will just stall let it sit for twenty to thirty minutes and will start and run fine for another hr. I have changed fuel pump flushed radaitor still have the same problem am getting very frustrated.
   / ford 5000 gas engine vapor lock #2
if it has spark at death, then next check for tank vacume. if no vacume.. then check to see if you are getting flow past pump to carb.
no gas insediment bowl already tried removing gas cap to see if pressure problem
   / ford 5000 gas engine vapor lock #4
so., you already know it'd not getting fuel flow.
i guess this post was just an exercise in typing them?
you have gas in tank.. and none in bowl.
answer seems simple. ???
already replaced fuel pump twice next step i guess is rebuild carb ?
   / ford 5000 gas engine vapor lock #6
Sounds like next step is to find out why fuel is not getting out of tank. Dirt, debris, etc?
forgot to add that I have replaced shut off valve at tank had to empty tank and clean to do that why would it start and run fine after 15 min or so anyway acts like it gets hot and vapor locks
   / ford 5000 gas engine vapor lock #8
We had a new Ford 4000 gasser my mowing partner used on highways back in the day that would vapor lock anytime it got above 80º-85º. Mechanic went through the diagnostics, then told us he'd be back in a half-hour or so... Brought back a bag of wooden spring type clothes pins, and clamped 2-3 on the fuel line. Ran like a champ afterwards.
I remember lots of Ford guys having them on their car/truck/tractor fuel lines, back in the 60's and 70's.
Might not solve the problem, but worth a try..!!
ha ha ha OMG I had an old farmer friend tell me about the clothes pin trick but i thought he was pulling my leg everyone laughed at me when i told them guess i will try now thx
   / ford 5000 gas engine vapor lock #10
How to cure fuel line vapor lock
I hate it when the weather is hot and the truck begins to stall. Assuming that your truck is in good running condition, the problem could be a vapor lock in the fuel line. Before we get to the cure, lets look at what causes this to happen.
Vapor lock is essentially when gasoline turns to a vapor. Not good in a vehicle since this will block the flow of fuel. In most cases, you pop the hood and let the engine cool. Once it cools down enough, you start it back up and you are on your way.
So what causes vapor lock. I have heard many folks say that it is caused by the engine heat. Well that is true - partly. The engine does contribute heat but the engine also has a cooling system which keeps the heat down. If not, the engine would overheat. The real cause is the engine compartment. Nothing is in the compartment to keep it cool hence the temperature can rise. Sure, you can vent the engine compartment but what we are trying to solve is a vapor lock.
The easiest way to prevent fuel line vapor lock is to go to the grocery store and buy a bag of wooden clothes pins. Take those pins and clamp them to various places on your fuel (specifically in the areas where it is getting hot and vapor locking). In order for the vapor lock to occur, it must heat the fuel and the fuel line to a temperature that will turn the gasoline to a vapor. By attaching the clothes pins, you are basically creating a heat sink. In order to heat the fuel and line, it must also heat up the clothes pin. It cannot raise the temperature of the clothes pin hot enough to create a vapor lock hence the problem is solved.
Ok, so this will not look real cool. Another solution is to purchase insulation for the fuel lines. This can be purchased at most racing shops. They run the fuel line very close to the headers and they get RED hot. This stuff is not cheap but it will work.
Another solution is to vent the engine compartment? How? Not really sure but if the temperature in the engine compartment stays low enough, you will not have the vapor lock either.
So what happens if the lock occurs in the fuel pump. They make insulators for those as well. Again, go to the store and purchase these blankets and it will keep it nice and cool. Remember that it is insulating from the heat inside the engine compartment and not the heat from the engine. They make these blankets for just about anything but personally, I would try the clothes pins first. You might be surprised.
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
1999 Budweiser Beverage Trailer (A51572)
1999 Budweiser...
TAKEUCHI TL230 SERIES II SKID STEER (A51246)
TAKEUCHI TL230...
