Kevinford5000
I had a question about the differential lock system. The shaft doesn't return back to the passenger side like it should to raise the diff lock pedal back up when you release the pedal. (I have the top cover off) Has anyone ever rebuilt the diff lock linkage/shaft or the lock itself? The lever that the shaft pushes on has very little throw and doesn't return either. It looks like it connects to a clutch pack. How does this system work? What is normal?
kevin
kevin
