ford 4610 serial/vin number? 1982
   / ford 4610 serial/vin number? 1982 #1
Young Ed
Kent
Ford 4610
ok i have started the process to try and get a v5 (not sure if you have it in US but here in the UK it is basically the document that shows that you own the vehicle etc and is a legal requirement for road driving and you need it to insure and tax) and it wants the VIN,chassis or frame number. this is for a ford 4610 from 1982 in the UK
i have found in various places what i think might be this VIN number, it is labeled as 'tractor number' or 'serial code' is this what i am after? is so any idea what this number means? '*B520177*' (printed with stars on tractor)
have got another code with stars before and after it but i can only find that stamped in one place.
the code i have put on here was found on a plate in the cab and on a sticker under the right hand bonnet
many thanks
Cheers Ed
   / ford 4610 serial/vin number? 1982 #2
The sticker under the right hand bonnet gives the serial number the model number, the manufacturing date and I believe the transmission code or the hydraulic pump code, The B indicates it was built at Ford's Basildon factory in the UK. The serial number is also stamped into the casting just above the starter. Cheers
great stuff, thanks!
so is this the official VIN number unique to this tractor then?
Cheers Ed
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
Mahindra Off-Road Buggy (A50121)
Mahindra Off-Road...
Unused Delta Crash...
