Ford 4610 Neutral Safety Switch
   / Ford 4610 Neutral Safety Switch #1
Mike Bi
Farmall H
I replaced the neutral safety switch on my 1987 Ford 4610 (8x4 trans with shifters on the column). Now, the tractor will only start in gear (high/low/reverse) and not neutral. Any ideas what I did wrong? I double checked to make sure it was installed correctly and exactly as the old switch came out. Levers were in neutral, etc.
When I crank in neutral i get nothing. As soon as i engage any gear on the high/low shifter it cranks right over. My understanding was that, when in neutral the ball at the bottom of the switch is "open" acting as a ground for the starter circuit. When in gear the ball pushes up, closing the circuit and not allowing the tractor to start. I don't understand how I could have possible reversed that by changing the switch.
If I can't figure this out I will have to bypass the switch because it's more dangerous as the tractor now HAS to be in gear to start.
I think I may have ordered the wrong switch :LOL:
82" Pallet Fork Extensions, New (A47371)
82" Pallet Fork...
2018 Ford F-150 Ext. Cab Pickup Truck (A46684)
2018 Ford F-150...
24ft Corral Panel (A49251)
24ft Corral Panel...
Poly Dolly (A49251)
Poly Dolly (A49251)
TOFT 1000 Hydraulic Breaker Hammer (A49251)
TOFT 1000...
2000 HEIL  44FT TANKER (A45678)
2000 HEIL 44FT...
