ford 4600
   / ford 4600 #1
GERALDV
It's hard to go into gear and how do I tell if clutch is bad
   / ford 4600 #2
Well, exactly what do you mean by hard to go into gear? Is it hard to shift or does it grind when trying to shift? Could it be the clutch pedal is out of adjustment, not sure of the exact amount of free play you should have but is it more than 1", just a thought but has the machine been sitting and the clutch is stuck to the flywheel? I have always used the high gear and brakes method to check the clutch, put the machine in high gear apply the brakes really hard and with the throttle at about 1/2 to 3/4 slowly let the clutch out, if it stalls clutch is likely to be good, if it doesn't stall the clutch is more than likely bad as long as the pedal adjustment is ok.
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
