ford 4500tlb parts
/ ford 4500tlb parts #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
Does anyone know of any good sources of parts, mainly backhoe pins and bushings for the old ford 4500 tlb?
ford part #: (bushings)
290621
290624
7701104
/ ford 4500tlb parts #2
To do all the pins and bushings on your BH would exceed the value of the machine if you went OEM and got from a CNH dealer.
Luckily, I have access to a lathe. So on my ford 5500 and dads 4500, we made our own out of 4140 pre-hardened. Not quite as hard as OEM, but is sufficient.
Whatever you do, I wouldnt go mild steel and certainly avoid brass/bronze bushings.
Both the pins, and the bushings on both our BH's were Rc58-60. And alot of the bushings are actually split bushings. If you dont have a lathe, its going to be expensive no matter what you do, just because of the shear number of them if you plan on doing them all. IIRC, There is 1 bushing in the bucket end of the dipper, and the two bucket pins. The boom to dipper has 3 bushings and a pin. the boom to swing post has 3 bushings and a pin that is threaded with a nut. Then each cylinder has 2 pins, and usually 3 bushings each, and thats 3 cylinders. Then the two swing post pivots, so theres a couple of pins and 4 bushings. And a center pin and a pair of bushings in the swing chain.
So quick count is about 22 bushings and about 15 pins. Expect that to add up around $3k at a ford dealer.
I would find a local shop to price making some for you. But you want some tight tolerances. Almost press fit. Because a few thousandths in each pin, times the number of pins, multiplied over a 15' reach = lots of slop.
Good luck on the endeavor, I faced the same delima when re-doing our BH's. And just couldnt source the parts as nothing was really a standard size or length that could be gotten in a hardened bushing from places like mcmastercarr.
And a tip....a logsplitter makes an awesome horizontal hydraulic press for pressing in/out pins and bushings.
/ ford 4500tlb parts #3
Paint Valley Equipment might offer the pins you need. I think they sell through a dealer network, but they might be able to help.
paintvalleyequipment.com
New/Unused Wolverine 43in Mini Rock Bucket (A65583)
New/Unused...
Hardi Navigator Pull-Type Sprayer (A66285)
Hardi Navigator...
2017 Freightliner M2 106 TMA Attenuator Truck (A64194)
2017 Freightliner...
1967 Hyster C35T-3 Equipment Trailer (A66285)
1967 Hyster C35T-3...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
