Ford 4500 shuttle shift
/ Ford 4500 shuttle shift #1
gammer
Bronze Member
Nova Scotia
Ford 4500 tlb
Just finished replacing all the bearings and cups in the transmission, also replaced second gear. I reinstalled the shafts and torque to spec, then spun the shaft with no load and it is sticking after one complete revolution, you need to give it a quick snap to free it up. I removed all shafts and put them on a lathe all are good not bent has feared, but that leaves a big question what is causing it. I will get the inner race gauged that the top gear fits into to see if this is causing the problem. have alot of money invested! need to get this running....
Anyone ever had this problem!!
excepting all suggestions feel free!
:confused:
Ford 555C 4x4 Loader Backhoe (A59228)
Ford 555C 4x4...
2023 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2023 CATERPILLAR...
DEUTZ MARATHON...
2026 tilt trailer (A56859)
2026 tilt trailer...
(INOP) 1996 FORD F SERIES DUMP TRUCK (A60430)
(INOP) 1996 FORD F...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
