Ford 445C 3 point doesn’t raise
   / Ford 445C 3 point doesn’t raise #1
runharley52
Bronze Member
Iowa
1990 Ford 445C; 1989 Ford 4610, Westendorf TA-25 FEL
I started it up to do some box blading and it worked fine. Made a few passes and it wouldn’t lift it up at all.
The draft control hasn’t worked since I bought it (more in this later), but 3 point always worked well.
Fluid is all good and it showed no signs of issues before this stopped.
I have a 4610 and when I move the position control I can hear the linkages moving under the seat/cover, but I can’t hear anything on the 445C.
So I got brave and took the lift cover off with a hoist, but only 4-5 inches up.
I can see the draft control linkage snapped in half, but like I said, I knew that was already broke.
When I move the position control lever nothing moves internally other than the shaft itself. I have the repair manual and it looks like it should be moving the position rollers.
My bravery ended there and I put the cover back on.
Anyone dealt with this before? Is what I’m describing in the linkage likely the issue? Thanks I’m advance!
2022 Caterpillar 906M Compact Articulated Wheel Loader (A55787)
2022 Caterpillar...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2019 KENWORTH T680...
UNUSED RAYTREE RTSG30 TRANSVERSE STUMP GRINDER (A54757)
UNUSED RAYTREE...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
