Hawkeye3828
I recently purchased a Ford 4400 '65-68 three cyl. and I am going thru it bit by bit and replacing/fixing the obvious. I drained the trans oil today and it was caramel color and I know it has water in it. I also drained the rear end and that just looked like very old oil but not carameled like trans. I looked thru the fill ports on both and I can see rust on the castings put the gears look good, no rust.
My question to you expert mechanics is "Should I be concerned about the remaining milky oil residue left inside the trans on the walls etc. or not?" I am not using this tractor to do a lot of work, just pulling some logs and bush hogging a couple of times a year. My own experience tells me to just refill with new oil and not worry about it but I decided to ask someone with experience to assure me of that. I am letting it drain for a day to get as much out as possible. Thanks for the advice.
