Ford 4400 TLB with 753 backhoe need to adjust pressure relief valve
   / Ford 4400 TLB with 753 backhoe need to adjust pressure relief valve #1
richwilshaw
romayor tx
ford 4400 tlb//ford 641 workmaster//yanmar ym1900
Hi there i am having a problem with my 753 backhoe that is mounted on a Ford 4400 1965 i believe
The dipper cylinder is bent again and i am starting to consider that my pressure relief valve is stuck, dirty or needs adjustment
The only diagram i have of this assembly is on the New Holland parts diagram, i have read somewhere that you take off the acorn nut and had or remove washers to adjust pressure.
So my question is has anybody ever adjusted this valve?
Any help would be appreciated
Thanks, Richwilshaw
   / Ford 4400 TLB with 753 backhoe need to adjust pressure relief valve #2
Do you know the tractor relief pressure, and do you know the BH relief pressure.
Do you have a manual.
Does our BH have a separate pump.
You need a 3000 psi hyd gage to check the pressure.
You can either plug it into a QD, or mount it in a tee in the IN port of the first valve after the pump.
Some relief valves are set by shims, and others are set by adjusting a nut on the relief poppet shaft.
IF it is shim adjusted, go to your dealer for the machine and purchase a relief shim kit. There will be several sizes. Read the instructions.
Should set the relief about 100 psi below the pumps max pressure, or what the manufacturer suggest.
   / Ford 4400 TLB with 753 backhoe need to adjust pressure relief valve #3
I have the exact same TLB. The nose pump sends pressure to the BH then PB to the loader. I don't have my service manual in front of me, its at work. I'm pretty sure the BH cylinders have their own relief valves because the relief pressure is different for each cylinder. I can check tomorrow and snap a picture or two of what it looks like. I'm going by a bad memory but I "think" you'll need a 5000 psi gauge to help trouble shoot.
Thanks for the help
I have a manual for the tractor but not for the loader backhoe version
The backhoe and loader hydraulics are driven by a pump mounted off the crankshaft pulley
Thanks for the help i appreciate it.
   / Ford 4400 TLB with 753 backhoe need to adjust pressure relief valve #6
I'm looking at the service manual. @ 165* hydraulic temp. And 1700rpm the system relief should be 2200+\- (50) psi. The main control valve has (4) circuit relief valves for overload protection: 4000psi protects the crowd cyl. piston end. Two relief valves are in the lift cyl. circuit, both set at 3500psi, at each end of the lift cyl. One relief valve, set @ 2350psi, is at the rod end of the bucket circuit. It has 2:1 ratio between the rod & piston end. The rod end should be 4320psi.
I hope this helps but there is a whole lot going on & I highly recommend getting a service manual. There are 18 pages(front & back) of pressure checks on the 750-755 BH.
Good luck, Keep us posted and snap some pictures of your repairs.
Thanks City Farmer looks like i will be buying a service manual.
The cylinder is off right now to get rebuilt or straightened at the shop.
The wife says that i am not using the backhoe right, i'm convinced its over pressure bending the cylinder. Either way, she's probably right, she's always right
is this the manual i need to buy?
   / Ford 4400 TLB with 753 backhoe need to adjust pressure relief valve #10
That's the same one I have.
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
1973 Pontiac Grand Prix Car (RUNS)(TITLE) (A50774)
1973 Pontiac Grand...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
2014 Bobcat 15C Skidloader PHD (A50774)
2014 Bobcat 15C...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
