Backhoe Ford 420 Model / H.P. ID
   / Ford 420 Model / H.P. ID #1
djasinski1
ford 420
I just purchased a 1978 Ford 420 backhoe off EBay. I can't figure out the tractor model or what horsepower / motor is in it. I purchased the service and operator's manuals but there are many tractors listed all different than 420. Here's what is listed on the tag inside the hood and what I think I know:
Tractor # - C562656
C = Made in USA
562656 = this is within the series for a 1978 production run
Model - KD211K
K = HP series (but what does the K mean?)
D = Industrial Flat Deck (mine does not have flat decked fenders)
2 = Production Stage (?)
1 = Fuel Type -deisel (mine is a 3 cylinder deisel)
1 = Power Take Off - (No)
K = Transmission Type - (6X4)
Unit - 8A17B
8 = 1978
A = produced in 1st month January
17 = day of month
B = day shift
Engine = 7M07B (?)
Trans = 7H04C (6X4 manual trans)
Rear Axle = 7L24B
The oil pan on the motor is cast iron which I believe means it's an industrial tractor. The hydraulic pump is mounted up front at the bottom behind the grill. It is driven by a drive shaft off the front of the engine. Rear tires are 14.9 X 24, front are 7.50-16SL 6ply 3 ribbed. It has a backhoe model 19 389
Serial = CB I3474.
Does anyone know how to decipher the engine numbers (7M07B) and model info (KD211K)?
   / Ford 420 Model / H.P. ID #2
The K is for 4600/445. It's in the 4000 class, should be a 201 cu.in 3 cyl.(same engine as a 4610, 455, etc)
The D is for industrial. (not a 4000, 4610, 4600), so, it would be a 445 or 455 depending on which loader.
The 420 was only made a couple of years, just sorta slipped into the lineup. But would be the same or similar as the 445/455
The engine numbers, they're just date codes of when the components were made, 7M= 12/1977 ( the letter I is skipped over, looks like a 1) the tractor being assembled in 1/1978
   / Ford 420 Model / H.P. ID #3
WOuld you know part number for ignition switch?
Schulte CF05 Rotary Mower Deck (A44571)
Schulte CF05...
Fleco 36" 13.5-15.5T Excavator Bucket (A42203)
Fleco 36"...
2007 INTERNATIONAL L9427(INOPERABLE) (A45046)
2007 INTERNATIONAL...
2015 KENWORTH T800 (A45046)
2015 KENWORTH T800...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2019 KENWORTH T680...
2015 FONTAINE STEPDECK TRAILER (A45333)
2015 FONTAINE...
