Ford 420 industrial tractor tach. not working /long upper cable to inst. cluster good / gears in oil pump that drive tach. turning .
   / Ford 420 industrial tractor tach. not working /long upper cable to inst. cluster good / gears in oil pump that drive tach. turning . #1
gtflyboy
Greenfield Twp. Pa.
ford/kubota
Ford 420 industrial tractor tach not working / long cable to tach in inst. cluster good / the 2 gears are turning in oil pump 1 that drives the cable turning with
tractor running ok . purchased and installed new short cable that goes into oil pump drive gear first . Yet long cable to tach is not turning when assembled ? Is it possible this short drive cable comes in longer lengths. or am I failing to see another problem ?
   / Ford 420 industrial tractor tach. not working /long upper cable to inst. cluster good / gears in oil pump that drive tach. turning . #2
There is only one length of the short cable. It is difficult to get it seated and could be it is not driving the long cable.
Thank You for that info. Tractor tech: I will check it again . Have a nice day
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
FRONTIER GM1060E LOT NUMBER 249 (A53084)
FRONTIER GM1060E...
(1) Drum of Algicide (A51573)
(1) Drum of...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
