FOrd 4110 steering fault
   / FOrd 4110 steering fault #1
sesese
dundee
ford 4110
hi I have a ford 4110 tractor 2 wheel drive with power steering , I bought it to repair as it had a hard life with a loader fitted ie front spindles and bushes worn out ( never seen grease in there life) the power steering Rams where disconnected I have since repaired the font spindles and bushes and then connected up the steering Rams and stared tractor up and the steering went to the Lh side hard lock with out me touching the steering wheel and I pyhisicaly can not steer it to the rh side with or without engine running , the only way to release it is undoing the Hydrulic steering pipes on the ram , certainly a mystery to me has anybody had the same fault on a ford tractor like this
   / FOrd 4110 steering fault #2
Your first check is to see if the steering valve is plumbed correctly.
View attachment FRONT AXLE%2C POWER STEERING %26 RELATED PARTS - 2100%2C 2110%2C 3100%2C 4110%2C 4140.pdf
If the plumbing is correct you most likely broke one or more of the centering springs.
Steering Column Parts Photos by john_bud | Photobucket
Care must be taken in the dis-assembly of this valve. You should have a camera to document the dis-assembly. You will also need a pliers with brazed tips or some other means of extracting the plungers without marring their surfaces.
Mike
Hi thanks for the info and diagrams ,I am going to strip it tomorrow for further investigation . I will keep you posted on the out come
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
1996 CLEMENT END DUMP TRAILER (A52472)
1996 CLEMENT END...
Charlotte County (A50323)
Charlotte County...
