Ford 4000
   / Ford 4000 #1
Russ5160
Hi. My 3cly diesel sounds like it is skipping, but it’s not smoking and it doesn’t feel like it’s lost any power. This is an intermittent problem. When it skips, it skips just a little, if you know what I mean. Checked the coolant and oil and there’s nothing out of the normal. Any ideas?
   / Ford 4000 #2
If u loosen the inj lines 1 at a time and listen for the miss..
U can narrow it down to A cyl..
THEN swap that injector to one furthest away from the suspect hole.
Hope this helps.
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
Tree Boom (A50322)
Tree Boom (A50322)
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
