Ford 4000 w. 8 speed, hi.lo pin broke
   / Ford 4000 w. 8 speed, hi.lo pin broke #1
john15nlt
Bridgeport Texas
Ford 2000 1969 gas / Ford 4000 1973 Disel
Was pulling a disc today and the hi/lo jumped out of gear, when I went to put it back it wouldnt go in, turned the tractor off and back on pulled rest of trans out of gear, and with a hard push it went into to low, the the shifter went limp.
I took it back to the house and pulled the shifter cover off and found the hi.lo pin broke at the neutral shift switch. After fiddling with it, I put it back to gether and can still get low but because hi requires a pull on that lever and not a push I can not get any high gears.
I have a manual and it shows the pin, but it doesn't show whats behind the pin inside the trans. My guess is when I pull it apart I am going to find that the part I broke is actually pushing up against something else and cotter or something similar holds in it place.
Anyone know for sure?
   / Ford 4000 w. 8 speed, hi.lo pin broke #2
hut down rickb, whodat or ultradog.
both of them have a ton of 3 cyl machine experience ( where you see the 8spd start.. etc.. ) I'm more of a prior model guy.
good luck
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
Quick Attach 6' Snow Blade (A50515)
Quick Attach 6'...
