Ford 4000 vs New Holland TN 70
   / Ford 4000 vs New Holland TN 70 #1
crazyhorsemd
cincinnati, Ohio
2000 New Holland TN70, 1974 White 1370
Looking at 2 tractors Ford 4000 and NH TN 70 2WD. Don't have hours on either ( yet) Both very clean, good metal the 4000 $4900 TN 70 $7800. Looking for opinions, what to watch out for, reliability ... Using around small "farm" 6' flail mower...
Thoughts?
   / Ford 4000 vs New Holland TN 70 #2
Thoughts?
The TN will have likely have better hydraulics, operator comfort, and gear selection. BUT, the 4000 will easily complete general "small farm" tasks. Don't get me wrong, 4000s are very nice to operate, but any newer tractor will usually have the improvements mentioned. The biggest complaint I can think of would be the noise produced by the 3 cylinder diesel in the 4000. If that 4000 is in good shape and doesn't need a bunch of work, and if you take care of it and store it inside, your cost of ownership would be next to nothing. I would bet that 5 or even 10 years from now, there will be buyers lining up to purchase a nice 4000 for $4,900.
A 4000 that is for sale and in truly good shape may be a little tricky to locate. The first thing I look at is the pedals and the front axle. How bad are the dimples worn off the pedals? If they are completely worn off, then your're looking some hours to do that, or possibly some loader work. Check out all the movement in the front axle. It is best to jack up the tractor, but usually not convenient unless it has a loader on it. Look for anything loose, or excessively worn. Most of the front axle items are easy to obtain and are not especially expensive, but they do take some work and are a good general indication of how the tractor may have been maintained (or not).
Thank you
Really appreciate the advice
   / Ford 4000 vs New Holland TN 70 #4
The old iron 4000 would get my vote based on my history with them. Today I have a 1966 3000 and 1980 3600 diesel. I think the 3000,4000 and 5000 are some of the best general use tractors out there today and the parts are out there as well. The 4000 has wet brakes which is positive in my experience. If the 4000 is not totally worn out today expect it to be a good tractor for a couple more generations. These tractors were built to run 20 hours daily and often did putting in a crop and then harvest season. Either tractor is fine I expect but I just do not know the post Ford era when they went to Italy (New Holland). All 3000 - 5000 models had UK built engines as far as I know.
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
2025 New/Unused Min Skid Steer Loader (A51573)
2025 New/Unused...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A52576)
2012 VOLVO VNL...
