FORD 4000 Valve Adjustment
   / FORD 4000 Valve Adjustment #1
number two
Veteran Member
Northern Lower Michigan
Kubota B3030HSDC Kubota L2501HST
Greetings-A friends neighbor dropped off his !966 Ford 4000 diesel for a general service job,which I can do this winter in my spare(?) time. I owe my friend big time,so I'll make the time for it. The usual-oil change,coolant exchange,grease,fuel filters,new tie rod end,new lower radiator hose heater,etc. The unit has about 3200 hours. Going through the owners manual,it calls for a valve adjustment every 600 hours. No one can remember this ever being done. I notice the procedure given has the rockers adjusted with the engine warmed up and running. Can't say as I've ever run into this before,and am not sure it has to be done this way.
Can anyone comment on this-do it running or stationary? Also,the loader is still on it,and it looks like a pain to remove. Will I have room to get the required services performed?
Thank you in advance for your responses.
   / FORD 4000 Valve Adjustment #2
   / FORD 4000 Valve Adjustment #3
Dunno about the 4000, never adjusted mine. Maybe I should.
Used to adjust valve lash on old Chevy stovebolt sixes while they were warmed up and running. The ones from the early 50s had solid lifters.
Wasn't hard; was kinda messy. You set them to have some resistance to moving the feeler gauge while on the loose or low part of the cam lobe. Of course it would tighten up considerably when the cam opened the valve, so there was little chance for confusion.
In order to get the feeler gauge between the valve stem and the rocker arm to begin with, the clearance had to be extra loose. I always tried to err in the direction of too much clearance as opposed to too little. Not sure if diesels are the same.
FWIW
Bob
   / FORD 4000 Valve Adjustment #4
I had the same issue with my 1700. I have a link below with bunch of good info that guys shared. bottom line, doing hot can be done but quite messy. Doing it cold much easier and clean. There were recommendation on types of tools to use to do it with the engine running. I ended up bringing each piston TDC with the cold engine, measured the gap with feeler gage and the measurement was up to par with the specs and that's where I stopped. I did not want to dork it up as the engine sounded fine and no lifter noise was evident even when I used my automotive stethoscope to take a listen
JC,
http://www.tractorbynet.com/forums/nh-owning-operating/92208-valve-lash-adjustment-my-f.html
Gentlemen-thank you for your replys. Per your suggestions,I called the guy and he brought me over the I&T manual. Why didn't he bring it first time? Anyhow,it gives a stationary procedure,#1TDC-adjust 3 valves,turn 360-adjust the other 3. I just knew there was a way.Although if it looks too tough with the loader on,I'll have him bring it back someday with it off.
JC-jetro,very interesting thread about valve adjustment. Reminds me of rebuilding small block Chevy engines-always had good luck with the static adjustment on the engine stand-those rockers squirting oil all over the engine compartment. And those clips flying off-AH!
Geez,TBN is not only a great place for information,it also provides great memories. Thank again guys.
   / FORD 4000 Valve Adjustment #6
I knew the manuals would help ya.. I got them setting here and they both have a valve adjust procedure in them.. etc..
soundguy
1989 Freightliner Cabover FLA086 (A52748)
1989 Freightliner...
New Holland L225 Skidloader (RIDE AND DRIVE) (A50774)
New Holland L225...
Army Generator (A50774)
Army Generator...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
