Ford 4000 transmission question
   / Ford 4000 transmission question #1
Barely Runnin
Orono, MN
Ford 4000
Machine is 1965, 3 cyl gas. with 8 speed tranny.
When plowing snow yesterday (lots of shifting between reverse and forward), I noticed the shift lever was moving way left of it's normal position in 5th gear. The lever has a slight bend in it near its base, I suppose to bring the lever ends closer to the operator. Yesterday, I could move the lever from about a 6 o'clock position to a 9 o'clock position, even while in gear. The lever felt pretty sloppy/loose. I was able to shift many times after the problem was noticed - I was just more careful.
Am I on the verge of having something fall off inside the transmission? It's too cold (below 0) to dig into now but I thought I'd ask about what I can expect to see when I remove the top cover the shift levers go through.
   / Ford 4000 transmission question #2
The locating pin in the shift lever is worn, as is the slot in the shift cover that the pin engages. Typical situation. My 4000's large shifter rotates about 60 degrees. one of these days i suppose I'll fix it.
2012 MERTZ/ S&S BLENDER UNIT (A50854)
2012 MERTZ/ S&S...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A49461)
2000 Trail King...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
COIL TUBING FRAME (A50854)
COIL TUBING FRAME...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
Swamp Buggy (A49346)
