Ford 4000 Tachometer not working
   / Ford 4000 Tachometer not working #1
fibrostic
I just got my "new" tractor. After countless times of coming to TBN for advice (thanks soundguy) my 8n is running well enough to sell. So I bought a Ford 4000 3cyl diesel (still trying to locate the serial to determine year) This has the generator with the Tachometer screwing in to the gearbox on the back. I unhooked the cable from the generator and spun it by hand and got the tach gauge to move, so I know that the mechanics in the cluster are good and there is not an internal break in the cable. I started the tractor and I can see the gearbox on the back of the generator spin, so no issue there either. Seems like i am missing a collar or a shaft of some kind that slips over the metal on the tach cable and that snugs up in the gearbox?
On a seperate note. The fuel and temp gauges also do not work. I pulled the cluster and found a mouse nest behind the panel. Cleared that all out and tested the power going to each side of the cluster (one for each gauge i think) and got good readings. Also checked the ground to the cluster and it read good as well. Thoughts?
   / Ford 4000 Tachometer not working #2
There are 2 screws holding a cover on the gearbox on the back of the generator if I remember correctly. There is a fiber gear in there that generally is stripped. It may be turning with no back pressure on it. But I bet you need a new one. Check the terminals on the fuel gauge on the top of the tank. There should be a resistance reading there. Probably will show an open - needs a new float mechanism. It will last for a little while. My experience with my two 4000s. A stick works real well. Be carefull you will waste more fuel with the stick than you will running it. Temp sensor is up front behind the fan.
Good luck - great tractors!
Bob
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
2022 Club Car...
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
2025 25ft. 800Amp Extra HD Booster Cables (A48081)
2025 25ft. 800Amp...
