Ford 4000 rev counter
   / Ford 4000 rev counter #1
08mckerp
Ive recently bought a 1968 Ford 4000 however the rev counter isnt working. Ive followed the cable from the back of the dash and its not attached to anything. Does anyone know where its suposed to attach?? Thanks.
   / Ford 4000 rev counter #2
I may be getting out on a limb here but one of my brothers has a 4400 that has a generator instead of an alternator. The tach cable is connected to the generator, which was original equipment. Don't know when Ford started using alternators.
   / Ford 4000 rev counter #3
If the tractor is equipped with an alternator, the tach is driven from the engine oil pump drive which is located on the left side of the engine, approximately amidships, just above the oil pan flange. The switch to alternators began in 1972 so yours should still have a generator, in which case the drive is at the rear end of the generator.
   / Ford 4000 rev counter #4
Yep.. when most switch from a gen to an alt.. they cheap out and don't get an alt with a tach drive.. like a delco 10DN.. they get the cheap 10/12 SI model ( 35$.. etc.. )
soundguy
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2013 FORD F-650 (A50854)
2013 FORD F-650...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2010 SHOP MADE WINDMILL TRAILER (A50854)
2010 SHOP MADE...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
