FORD 4000 power steering pump
   / FORD 4000 power steering pump #1
PKSHARP
Hughesville, MD
FORD 4000 IND
HI folks new member and working on a restoration project Ford 4000 backhoe loader 4cyc gas 1964. Will begin to post pictures when I figure that part of the forum out.
When trying to pull the power steering pump pulley off I cracked it and need to make/ find another but I want to rebuild the unit also. It's the type with a round fluid tank attached to the top and mounts to the right side of the engine. the unit has two powered cylinders.
Question: Is there a equivalent ford car or truck pump I could use to replace it?
Kevin
   / FORD 4000 power steering pump #2
you can get non oem aftermarket pumps.. but I see some pricey ones.. like 600$
however.. if restoring it as you say.. i'd stay original.
soundguy
Thanks for the feedback, I may have used the wrong wording I am upgrading some items, 12V Alt, electronic ignition and electric cooling fan. I have read on some forums that 196X, ford cars used the same pump and was tying to spare the piggy bank more pain. I found a couple of pulleys online but they are asking $60+ bucks for just the pulley. so I ordered a undersized unit and will do some Lathe work on it.
meant to ask for a recommendation on where to get rebuild kit for the original pump shown in my post.
Kevin
   / FORD 4000 power steering pump #4
Thanks, I'll save the money on the fan.
   / FORD 4000 power steering pump #6
especially if trying to save money, the electric fan is a step in the wrong direction ...
soundguy
   / FORD 4000 power steering pump #7
Part # S.60189 from yesterdays tractor co. may be what you need. $650 is cost. If anyone knows how to clean out a power steering system with debris (filter desintegration) for this same tractor, let me know
   / FORD 4000 power steering pump #8
Line flushing is easy, cleaning the Ps block will require disassembly
   / FORD 4000 power steering pump #9
As for the power steering pump itself ,Late 50s to mid sixties Ford cars and later AMC products used the same pump. My 57 model 660 pump was worn out so I went to the junk yard and got one off a 68-69 AMC Ambassador. Just had to put my reservoir, mounting bracket and pressure line fitting on it. The pumps are actually Eaton single pulley separate reservoir pumps. You can still get a kit from NAPA. That's where I got mine.
   / FORD 4000 power steering pump #10
4 yr old zombie thread.. ;)
2011 INGERSOLL RAND  G70 GENERATOR (A52472)
2011 INGERSOLL...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
