Ford 4000 Broken Front Hydraulic Shaft
   / Ford 4000 Broken Front Hydraulic Shaft #1
newtraditionsfarm
Beaverville, IL
Ford 4000 1972 3-cyl Gas
Today I was working on my tractor (tilling) and noticed a strange burning smell, similar to straw or grass. I looked down at the hood of my tractor, and noticed a good amount of smoke coming from around the front hydraulic pump. When I stopped to investigate, I noticed that the shaft had split in two and was (obviously) no longer turning the pump. I fished out the broken part of the shaft and posted the pictures below.
I'm wondering whether I can replace just the shaft or whether the smoke means that the pump is shot as well. Also, is this a repair that a novice can attempt on their own?
Also, when I looked in the hydraulic reservoir I noticed that it was mostly empty. Is it possible that the pump seized up due to lack of fluid and cause the shaft to break?
   / Ford 4000 Broken Front Hydraulic Shaft #2
Hard to tell from here. Can you turn the pump over by hand or with a channel locks? If it doesn't turn freely then my guess is that you ran it out of oil and it froze up, seized and something had to give, that being the shaft.
That's about what I thought. Seems like a pretty simple repair? I guess the difficult part will be deciding which replacement pump and shaft are appropriate. (For instance, I can't seem to located a hub with three points like mine: Hydraulic parts Ford 4000 3 cylinder through 4835)
Any suggestions?
   / Ford 4000 Broken Front Hydraulic Shaft #4
does the pump turn?
check on ytmag.com for parts.. plenty of driveshafts and hub parts..
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2017 NISSAN Maxima (A50324)
2017 NISSAN Maxima...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
2018 NISSAN TITAN PICKUP TRUCK (A51222)
2018 NISSAN TITAN...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
