Ford 4000 3 cyl rough running and hard to start. HELP
   / Ford 4000 3 cyl rough running and hard to start. HELP #1
bach939
Michigan
Ford 4000 3 cyl
I got a Ford 4000 3 cyl that runs very rough. I had New Holland rebuild thr carb, but still have the same problem. When I installed the rebuilt carb, I couldn'get it to start. In doing some testing, I found I have no spark. Put on a new coil, but the same and rechecked the points. What I did discouver was jumping the + side of the coil to the + of the batt it started, but runs really rough and at time backfires. Took the jumper off and It started to settle down and ran pretty good for a while then back to the rough running thing. For sure, I have to do the same jumper to the coil to get it started. I pulled the three plugs and they were fairly black which tells me it's running rich. It runs better at low rpm's, but as I advance the throttle, it starts running really rough and backfires occasionally. Is there a possibility the vacuum advance is not working and why do I need to jumper the coil?
HELP!
2014 New Holland C238 Tracked Skid Steer (A50860)
2014 New Holland...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2017 Ford Escape SUV (A48082)
2017 Ford Escape...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A50860)
2025 K0311 UNUSED...
2012 Chrysler Town and Country Van (A48082)
2012 Chrysler Town...
