Oil & Fuel Ford 4000 3 cyl diesel tractor hydraulic filter question
   / Ford 4000 3 cyl diesel tractor hydraulic filter question #1
Nicolasticity
Bristol UK
Ford 4000
Where is the hydraulic filter on a 1967 Ford 4000 tractor and how do I change it. I note that the hydraulic / axle oil inlet is under seat, drain directly below and the level in the middle of the hydrualic lift feed where the rate control is but I cant work out where the filter might be
   / Ford 4000 3 cyl diesel tractor hydraulic filter question #2
There is a suction screen and return filter located in the rear axle center section. Replacing the return filter requires that the hitch cover be removed, and replacing the suction screen may require that the PTO output shaft also be removed. The screen usually can be cleaned in place with a solvent when the lift cover is off and the oil is drained from the housing.
2001 Ford F150 (A50121)
2001 Ford F150...
Kubota ZG327 (A50120)
John Deere L118 Automatic 42in Riding Mower (A51694)
John Deere L118...
2002 FREIGHTLINER FL80 FUEL TRANSPORTATION TRUCK (A52472)
2002 FREIGHTLINER...
More info coming soon! (A50323)
More info coming...
2006 John Deere 4120 Tractor (A51573)
2006 John Deere...
