FORD 3930
   / FORD 3930 #1
jlbash1
Bronze Member
Ohio County, Kentucky
Kubota L2650/Ford 3930
I'm looking at a Ford 3930 here locally. I've been looking for a 50 hp tractor for a while now and this one seems good. It is 2wd and has turf tires. I'll have to put R1's on it so that's a down side, it doesn't have a remote either which is another down side. On the up side it looks good and clean and only has 700 hours. They are asking $9900 for it, does this sound too bad? from what i've seen it's fair, but I like to hear what other people think.
Thanks in advance
Jarrod
   / FORD 3930 #2
Clean.. high hp.. low hours.. sounds like a steal to me.
I paid that much for a 33hp Nh 1920 a few years ago.
Ag tires aren't bad.. might even get a few bucks for the turfs if there is rubber on them...
Remote is the only downer.. but then.. that's not a deal killer.. even with dealer kit prices.
Soundguy
   / FORD 3930
I ended up buying the tractor for $9500. I'm very pleased with the deal. I'm so glad to be done looking for a tractor again. I bet I have a truck load of classifieds laying around the house I've accumulated looking for a good used tractor. I won't have to stop at the gas station on Wednesdays and Thursdays to get the new editions of the Thrifty Nickle and Show 'n' Tell anymore. Well there are some new implements I could use with the bigger tractor.............
Jarrod
   / FORD 3930 #4
That sounds like a good price. Congratulations! That 3930 tractor will run & run. You may want to start looking for some earplugs because the Ford three-cylinder diesels can get a bit loud.
   / FORD 3930
I did some mowing with it on saturday and that is the first thing I noticed, a big difference from the Kubota I have.
I ended up calling the deler because I thought the PTO clutch was shot though. I had the clutch pressed all the way down and engaged the PTO lever. The PTO started right up with the clutch depressed, I got worried. So I drove down the road to the neighbor's place to see if I was doing something stupid before I called the delaer I bought this tractor from. We decided that this wasn't right and I called. So appearantly this is what you call an independant PTO. I've heard of them, but didn't know that they worked like this. So it's working right I guess, I felt a little stupid after he told me that was how these things work. Oh well, we've all got to learn some way. I will admit though that I kind of wish I had more control of how quickly the PTO gets engaged.
All in all though I felt very pleased with the tractor's preformance. It felt very stable compared to my Kubota and it handled well. It was kind of sad disconnecting the mower from the Kubota and hooking it up to the new tractor though. I hate to see the Kubota go, it's been a great tractor for me, hopefully the Ford will be just as dependable. I kept grabbing for the shuttle shift lever on the left side of the steering wheel though, it's going to take a while to get used to this transmission compared to the GST on the Kubota.
Jarrod
   / FORD 3930 #6
Regarding the Independent PTO, I never used a 3930 for PTO work. This was new to me. I needed an education on the Independent PTO, as well. I learned something that I think you'll be happy to hear. Here is a quote from the New Holland 3930 brochure:
"The PTO is conveniently located at the operator's left, and can be engaged or disengaged at any time by simply moving a lever.
This PTO is featherable for reduced driveline shocks. When engaging the PTO, slowly move the control lever to the adjustable feathering stop. When the shaft begins to turn, push the lever completely to engage. The PTO engages smoothly, rather than with a sudden jolt."
The way I read it, the PTO is even better than what you had on the Kubota. Let me know what you think about this feature.
   / FORD 3930
I did notice an adjustment screw on the PTO lever, didn't know what it was for though. I don't have a manual as of yet. It just sets a stop point for the lever, the point at which the PTO starts to engage, then you can feather the PTO in from there. Sounds like it should work well. The only thing that I don't like is the lack of the "oh crap hit the clutch" factor. If you ever need to disengage the PTO quickly it would be harder to reach for the lever under the seat than to simply hit the clutch. It's raining here thanks to Rita, but when it dries up a little I'll play with it some more.
Thanks for the quote out of the brouchure that does set my mind at ease.
Jarrod
   / FORD 3930 #8
At least for mowing applications.. dual stage clutch VS an independednt PTO MIGHT add another second to spin down time. In either case.. when you stomp the clutch.. or kill the pto lever.. the rotary inertia is still there.. if it is more than the pto brake can handle.. it will still be spinning...
Soundguy
   / FORD 3930 #9
I had a 3910 with same PTO. You are correct about it engaging quickly. It doesnt opperate as the new tractors do with slowly engaging. You will enjoy this however when you back your mower into something to thick to drive over or turning around. It will allow you to shift while the PTO is engaged. The 3930 is a great tractor. Very very durable and easy to have repaired when needed.
   / FORD 3930 #10
</font><font color="blue" class="small">( You will enjoy this however when you back your mower into something to thick to drive over or turning around. It will allow you to shift while the PTO is engaged )</font>
Don't need independent pto for that... 2-stage 'live' clutch will let you do that.
Soundguy
1994 GMC Top Kick Grain Truck (A50514)
1994 GMC Top Kick...
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
Ford 610 (A50120)
Ford 610 (A50120)
