Ford 3930
   / Ford 3930 #1
chfrich
Kioti CS2210
I have a 1992 Ford 3930 with dual fuel filter system which is leaking. I have replaced all the gaskets but still leaks. Can I replace the dual filter system with the newer style single filter systems used on the newer Ford 3930 Tractors?
   / Ford 3930 #2
This was answered in the other category, but you can do a Racor system too. Where are your leaks? Just like @Harry in Ky said that he has changed hundreds of CAV filters over the years and not had a problem, I too have changed them without leaks. If the filter is leaking around the cartridge, then you left an oring in the head OR there is something wrong with the filter head.
   / Ford 3930
I have done many of these also. Changed all the gaskets and took apart three times still leaks. Going to take it apart tomorrow and see if i can find the problem. Just seemed like a solution to change to newer style single filter if that can be done. What part number would work? Thanks for your reply!
2013 BOBCAT S630 (A52472)
2013 BOBCAT S630...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2015 MACK CXU613 (A52472)
2015 MACK CXU613...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
2018 Bobcat T-450 (A51573)
2018 Bobcat T-450...
