Ford 3910
   / Ford 3910 #1
yooperdave
Veteran Member
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Does the Ford 3910 have a good track record?
Is this a good deal? FORD TRACTOR 3910
I am trying to get more of the specifics.
TIA
Yooper Dave
   / Ford 3910 #3
I've owned a 1987 3910 since new, and it's been a solid and reliable workhorse, it has never let me down. If you have any specific questions about let me know.
As for the price, depending on the hours and condition it could be a decent deal. It's a solid tractor, the front axle can handle lots of loader work. I don't think I'll ever get rid of mine (but I am looking at getting a mfwd with a cab in the near future).
   / Ford 3910 #4
I have the same tractor. If the hours are under 2000 I wouldn't call it a bad deal, especially if thatat is the original paint, then it is obvious the tractor has been well taken care of.
On the loader, the 3910's drawback is the front end is not a real heavy duty front end. You can do alot of loader work with it, but the front end is the weak spot. Radius rods and spindles take the brunt of the damage. When I got mine it had way too big of a bucket on it and I ended up breaking a spindle, I since have put a 6' skidloader low back bucket on it. I usually take the loader off when doing any field work, but one day I had a little mowing to do and when the left front went into a groundhog hole the radius rod broke.
Other than that I have not had a bad thing to say about mine.
If you do buy this I have a set of rear weights I would sell rather cheap + shipping if you are interested You may have to make a plate to adapt them to yuor rim and they are 95 lbs a piece.
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
