frankmako
Bronze Member
The auxiliary service control valve does not work. The three-point hitch works, but I cannot pull the A.S.C. valve knob out to the other two positions. Also, I cannot change the speed of the three-point hitch. The valve knob is set to the 吐ast setting (a good thing). The switch/knob will not move back and forth and it will not pull out. I also have a double spool remote control valves on the tractor. My book tells me to pull the A.S.C. valve handle fully out to operate external services only. Push fully in to operate the three-point linkage only (the position that it is in). And the mid-way position is selected to operate the three-point linkage and external cylinders simultaneously. It has a flat head screw on the front side of the system, could this be a stop/safety screw??? I guest that I should back the screw out some and see if I can move the valve.
frankmako
frankmako
