Ford 3610 power steering leaking from cap
   / Ford 3610 power steering leaking from cap #1
Toddg1969
Ford 3610
I have a Ford 3610 tractor shooting power steering fluid out of the reservoir and leaking out of the cap, when I fill it up it steers fine just ends up leaking all the fluid out, also it’s frothy fluid see videos attached. I’ve ordered a new filter and ORings just want to make sure the pump isn’t bad
   / Ford 3610 power steering leaking from cap #2
More likely the shaft seal is causing more problems than the filter. The filter actually does nothing in this system.
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2021 John Deere 9570R Articulated 4WD Tractor (A50657)
2021 John Deere...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
