Ford 3600 Tachometer Cable
   / Ford 3600 Tachometer Cable #1
TNSuperC
Bronze Member
Farmall Super C, Ford 3600
I've purchased several TISCO D3NN17365C cables and installed them with the same results: twisted apart within first few seconds of operation.
My opinion is this cable is too long at 48" and binds causing failure at the lower end. It is much longer than the OEM cable.
Any suggestions on how to keep this from happening?
All the cables I see on the web appear to be this same cable although their part numbers are slightly different.
   / Ford 3600 Tachometer Cable #2
I think the 3600 also has a short cable that makes the turn down into the engine block. Have you pulled it out and checked it? It's been a while since I changed one, but it's only like 6 or 8 inches long.
480/70R38 LOT NUMBER 135 (A53084)
480/70R38 LOT...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
SCAN TO RECEIVE TEXT UPDATES (A51248)
SCAN TO RECEIVE...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
