Ford 3600 rear lift all or nothing
   / Ford 3600 rear lift all or nothing #1
DarbyCrash
Ponchatoula La
Mahindra 5145
1979 ford 3600, recently purchased and have noticed the rear lift is either all the way up or all the way down when the lever is engaged. Has both levers for draft control and lift control. With implement on the ground, lift does not engage until the lever is almost to the 2,3 position and when it does, it travels straight up to top position. Same going down, lift doesn’t engage until around 2,3 position and slams right on the ground. Cannot float or pick lift position. Still in the process of “renewing” tractor and replacing broken or worn out parts and am getting to the hydraulics. Any insight is appreciated or what to check for next on the issue. Also the lift speed lever is stuck on fast. Tried to rotate it and completely broke off btw.
   / Ford 3600 rear lift all or nothing #2
What position is the draft control lever in, all the way up or all the way down. It should be all the way down.
   / Ford 3600 rear lift all or nothing #3
Cracked O-ring in the pressure relief valve. Same cause for symptoms on other brands. When you unscrew it from the trans, careful not to let broken pieces fall in.
It is all the way down. But still same symptoms regardless of draft control position.
10/4 and it can be changed without removing top cover? This is my first tractor I've owned, sorry for the newbie questions.
MacDon C3012F Corn Head (A53342)
MacDon C3012F Corn...
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
